Old 08-16-2004, 06:52 AM
mj_duell mj_duell is offline
Send a message via AIM to mj_duell
Thanks Ron,
When I first put pressure to the Demon (just out of the box) I was spitting gas out of the primary vent. I adjusted the level doen until it was half way across the site-glass. My secondary has always been half way across. I'm thinking both secondary and primary float levels need to come up. My Idle is between 1000 and 1200 depending on adjustments. When I did the four corner adjustments, I found that it engine kept looking for more fuel. It was satisfied when the screws were about 3/4 all the way out. I think the answer might be more fuel (higher float). What are your thoughts? Oh, what Idle RPM are you running?
--Mike
