Mike,
I have a rather radical cam also and vacuum is a problem at times. But when I talked to a Holly Tech. he told me that the gas should just be right at the bottom of the site plugs and that if I take them out it should just barely splash out at idle. My engine idles at 1,000/1,100 RPM. Let me know what you find that cures your braking problem as I still have some but not as bad as before and as I said, I am thinking of putting a small hose on the vents to raise the tops some.
Ernie, did you get yours to stop killing the engine under braking, and if so was it your carb adjustments?
