Old 08-19-2004, 07:06 AM
westcott cobra's Avatar
westcott cobra westcott cobra is offline
Cobra Make, Engine: Actual car: AC Autokraft MK IV with Keith Craft 331. Gone: Home built Crendon, original style twin tube frame, powder coated, stainless sidepipes. FE 433
Default Rear seal on Tremec 3550
Hello all,
my prop shaft made by a professional prop shaft supplier is made to fit my 3550 tremec.
But tremec is not a real common tranny her in Germany, therefore the company had a "inner" rear seal in mind as they fabricated the part according my drawing and measurements.
I found out the small problem directly during assembly but accepted the situation for the rest of the summer.
Now the rear seal of my tremec is damaged a bit and leaking because it is sealing "outside" and too far rearwards arround the unmachined part of the yoke.
I don't want to shorten my prop shaft!
Has anybody a part number for a rear seal mounted as the original part but going to the inside of the tremec?
Next winter I want to replace that leaking red thing by one not sticking out of the tranny.
Thanks,
Uwe
Everything should be as simple as possible - but not simpler !!
