Vern went with the tilton bearing. He had so much touble with the Mccloud. Did you have much trouble lining up the bell housing. I was at the shop when they lined up the bell housing, trans, bearing and clutch. Not an easy task. I have the 3.00 rear end Richm. 5 speed. 3200rpm at 75 mph. in 5th gear. I dont have pos. Seems to hook up well with out it. Both tires spin. The car seems to launch out of the hole. A lot diff than my 67 vette with pos. I haven t used the hard top that much to comment. It seems to fit well. I still need to put in a headlinner . Are you going to the big car show in Mich. this weekend I ve heard over 2500 car show for the run. Terry
