Old 08-20-2004, 01:21 PM
zipzip's Avatar
zipzip zipzip is offline
Cobra Make, Engine: Midstates work in progress, personally built 302
I moved the dipstick from the block to the timing cover. Fortunately, I was able to remove the freeze plug from the timing cover and put it in the block. You should be able to pick up the freeze plug (looks like a little cup) at a local parts store.
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
