Old 08-22-2004, 03:00 PM
pneall's Avatar
pneall pneall is offline
Found a few other things on weekend.
a) The area where the soft top ferrules fit is not flat on the drivers side. Easy to fix before painting but requires taper washers afterwards. Bow must be vertical otherwise window support wont line up with top of screen.
b) Front suspension has built in bump steer. Toes out on acceleration and in on braking. At least its not other way round.
c) Ran out of camber adjustment on rear. Will have to modify top arm to fix.
d. Good starting point for spring height ( no weight on car) if using AVO shocks is 240 mm.
e) Mike Murphys muffler design works real well. Nice note through the gears with no noise when cruising in 5th or 6th.
f) You can accelerate in 6th gear. Not startling but still picks up nicely.
g) You can start in 3rd gear. That means you can blow your licence without changing gear
Phil
