Leeroy,
Flexible duct from Motorsport Connection 1800 242 910. This stuff stays round but will turn 180 degrees. Its 102 mm ID.
Its silicone outer (high temp) with wire internal support. $82.00 per metre. I needed 1 metre.
At moment I have it clamped and taped to MAF as the MAF is about 90mm. At edit the MAF will be removed. I intend fitting 200mm of 100 mm Aluminium tube to front of TB. This will house air temp sensor. Haven't checked OD of TB yet, may need to machine up adaptor.
When is yours back from painting??
Regards,
Phil
