Old 08-25-2004, 04:29 PM
ItBites's Avatar
ItBites ItBites is offline
Cobra Make, Engine: Midstates, Vette suspension, Baer 6P brakes, 540 cid Chevy, Haltech Fuel Injection
My opinion: 245-250 deg at .050 is at or beyond the limit of what will work well with 9.5 to 9.0:1 CR. I would be happier with the low CR and long duration if it were 114 lobe sep (you'd develop more dynamic cylinder pressure). Further, those flow numbers are way below what I usually see for big HP motors. It looks like those are torque heads with a higher-rpm cam. May work OK, but I'm a little concerned with the longish duration cam, even though it is not super-long.
Just for comparison, my ported FACTORY BBC heads (on my 427BBC) flow ~400Intake/330 Exhaust cfm at .700 lift.
I have ~12.5:1CR and use ~265/270 deg @.050, .675/.685 lift roller
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
