Stroker vs stock lower end
Tony Radford
Stock bore & stroke
Engine: Ford 351-W (4" bore, 3.5" stroke) with Super Victor #2924 intake, 850 cfm carb, Victor CNC heads #7729, Crane mechanical roller cam #368211 and JE pistons with 13.25:1 compression
Results: 617 horsepower at 7500 rpm and 464 ft/lbs. of torque at 6500 rpm
even cut the compression ratio down 1.5:1 to run pump gas and still put a healthy HP rating. better than cramming your pistons into your cylinder walls.
GWC
