Old 08-26-2004, 05:52 AM
Cobra Crazy Cobra Crazy is offline
Post SOLD! FFR 3923 For Sale
FFR Mark II Roadster (FFR3923K) for sale. Car was on the road May of 2003. Since built I have put just over 6,000 miles on it with no problems.
I live about 40 miles west of Cleveland, Ohio.
Engine details:
Engine had been rebuilt . 6,000 miles on rebuild. It had 93,573 miles on it when rebuilt.
5.0L EFI
Explorer upper intake
GT40 lower intake
Intake heat spacer
Holly adjustable fuel pressure regulator
Stock heads (ported, 3 angle valve grind and FMS
1.6 aluminum)
Double rolller timing chain and gears
Under drive pulleys
New alternator
New water pump
New starter
New oxygen sensors
New spark plugs
New spark plug wires 8mm
New distributor cap and rotor
New clutch, pressure plate, throwout bearing and
pilot bearing
Moroso radiator T-fill
FMS stainless ceramic coated headers
Ceramic coated FFR side pipes
Energy Suspension polyurethane engine and trans
mounts
Electric cooling fan sender, comes on
automaticlly and also have manual switch on
dash
New radiator
Transmission:
5 Speed with Steeda Tri-axe shifter.
Trans was taken apart and new input shaft,
bearing, syncros and seals replaced.
New u-joints on drive shaft.
Suspension and Brakes:
8.8 Mustang rear end with 3.55 gear
FFR rear upper and lower tubular control arms
New rear shocks
Brake parts are all new
New e-brake cables from e-handle to drums
New US Wheels series 94 wheels with center caps,
June 2004
New GF Goodrich Radial T/A's, 235/60-15 Front,
275/50-15 Rear June 2004
FFR front fully adjustable upper control arms
with Pro Shock coil-overs
Mustang lower control arms with new bushings and
ball joints
New manual steering rack
Aluminum offset steering rack bushings
New steering shaft u-joint (replaces stock rag
joint)
Power brakes (95 Villager master cylinder with
remote reservoir)
MISC:
Tonneau cover, custom made to fit over Street
Performer Seats
Car cover with storage bag
Insulation under carpet
Russ Thompson throttle pedal, brake and clutch
pedal pads
Master cut off switch with jump studs in trunk
New fuel tank and fuel sender
Ceramic coated side pipes
Heater
Fresh air vents
Tri-axe shifter
Alumiunm / rubber roll bar bezels
Fuel cap that you don't have to remove to fuel up
Aluminum windshield mirror mount with Raydot
mirror
Street Perfromer Seats with Breeze seat mounting
brackets
Windwings and sun visors
Cigarette lighter plug-in
Fuel/air mixture gauge
Proform shift light (can set RPM that light comes on)
Paint
Candy Yellow with Black stripes (Base coat was
white mixed with clear - 4 coats, Color coat was
candy yellow mixed with clear - 4 coats,
stripes have 3 coats and top coat has 3 coats
of clear)
Click on this link to see pictures of the car http://community.webshots.com/album/131335670MtSiDM
Will include a CD with pictures of complete build
Will e-mail pictures if interested. Will e-mail my phone # if you want to talk!
If you have any questions, just ask!
Asking $28,000 OBO.
Thanks, Jim
