Old 08-26-2004, 07:46 AM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
Make sure the intake manifold gasket is flush with the manifold/heads where the valve cover gasket passes over it. Sometimes the intake manifold gasket will stick up by about 1/8 inch or so making it nearly impossible to get the VC gasket to seal properly. If it does stick up, just trim it down so it's flush.
Chris
