Old 08-27-2004, 09:40 AM
RedCSX1's Avatar
RedCSX1 RedCSX1 is offline
Cobra Make, Engine: Shelby CSX 4766 (Vegas Built) with 482 Aluminum Pond motor
Lightbulb OK, Here you go.......
Clean both surfaces with brake cleaner or similar solvent. Glue the cork gasket to the valve cover using good quality RTV. Let sit lightly compressed overnight. Then coat the otherside with wheel bearing grease. Attach the valve cover to the head. Uniformily tighten the vavle cover bolts. If you ever have to remove the valve cover again you can still reuse the gaskets. Give it a try then tell me how you like it.
Good talking with you Allan.
Morgan
Morgan LeBlanc
Fresno CA
