  #22 (permalink)
Old 08-27-2004, 03:40 PM
ItBites's Avatar
ItBites ItBites is offline
Cobra Make, Engine: Midstates, Vette suspension, Baer 6P brakes, 540 cid Chevy, Haltech Fuel Injection
Priobe,
Just to clarify; the cam gear is not changeable. It either comes from the cam vendor with the std steel gear (cut into the cam billet material) or it has the optional presssed-fit cast iron gear.
If cam has steel gear - distributor needs bronze.
If cam has iron gear - distributor gear is stock.
If you use bronze dist gear be prepared to check occasionally for backlash and replace as required.
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
