It's a medium riser. Of course the carbs will need a complete rebuild. The intake looks to be in good shape.
Is it "real"? I guess so. Is it a "big deal"? Might be to somebody. Fact is this item would be impossible to document as anymore "real" than any other Ford OEM medium riser alloy intake manifold. The carb will need a total "restoration". When your done I'm not sure you got anything more valuable than two old carbs and an OEM medium riser alloy intake.
MUCH more rare is the High Riser dual four OEM alloy intake which typically sells for $600 to $700. A couple of old used Holleys might be worth $50-$75 bucks per carb.
4 to 5 hundred would be my guess.
