GR,
If you have the Heidt's, FatMan, or similar inner suspension locating points you WILL NOT improve you handling by merely changing arms.
The 8840 Comp AC/COBRA suspension that makes these puppies handle great have different inner ear suspension pickup points than the STOCK MII points that the rodders use.
Give me the dim on pvt MAIL from the front inside arm point to the other.
You will probably be fighting a GEOMETRY problem, not purchasing pieces problem.
grumpy
