08-29-2004, 06:39 PM
QLD
Cobra Make, Engine: G-Force, 351W, GT40 Lightning Intake, Toploader, Jag running gear, 3.07 diff, Autronic ECU
Hi Chris,
Nearly there mate...keep at it.
Question for you....if both front brakes were locking up at the same time then would the engineer have passed it ? If so then you just need to get them balanced left-to-right rather than replacing the calipers. I assume you've bled them well. Could be a seal as Brian suggested but a good brakes place should be able to find the problem. Could be the pads bedding in if you haven't worked them out yet ?
Just a thought.
