Best time with a worked 351W was 11.40 at 121mph with 3.73 gears/Tremec/15" BFG DR's, launch at around 3200rpm ,granny shifting as fast as I could . Sixty foot was not working. Past attempts after a practice run, if 60 fts can hang in the 1.7's is mid/high 11's ranging 118-122 mph depending on psi. Three years ago Roll Out (21psi) versus Launch (15psi) on that same day showed 12.0-1 at 120 mph versus 11.54 at 118mph. The launch showed lower mph (psi) but 3-4 tenths gain in 60ft made the difference. This season I intended to try power shifting , learning better launch techniques but budget reality crushed that enthusiasm and driving home became the bigger thrill .
