Thanks David,
That will be excellent. I only need the heads to make paterns for the intake plates so having the valves out will make life easier. I'll be able to get a scribe up through the intake port to mark out the holes. The manifold will be handy too for working out the angles for the injectors and for the hold down bolts.
I'll swap you my single pump swirl pot setup for a pair of fuel pumps. I've decided to make a twin pump swirl pot with an external regulator. Probably don't need the extra fuel but I like the idea of having a bit of headroom in the system.
Mike Murphy
Melbourne Australia
