  #41 (permalink)
Old 09-01-2004, 08:39 PM
Keithc8 Keithc8 is offline
There were some questions about the air fuel ratio on the dyno sheet and they are a little high. I also had exhaust parometers in the exhaust pipes checking the temps. The exhaus temp was running about 1200 to 1250 through out the pulls and this is well in line. I will have to check the fuel flow meters or air turbine and make sure they are reading correctly. I do believe the engine was running more like 13.5/14 to 1 on air fuel. We will also check this at the othet dyno facility.
I just wanted to correct some miss statements. I do not post or talk about every engine we build nor do I have the time. I have not been posting on any of the engines we have built lately because of the problems it seems to cause. I know and the customer knows and that is enough. Thanks Keith
Keith C
