Old 09-02-2004, 02:28 PM
Ron61's Avatar
Ron61 Ron61 is offline
Post
Clois is right. That is a huge leak for a rear main. Do you have an inspection plate on the bottom of your scattershield? If so, remove it and look inside. If the leak is from the rear main, it will be wet in there. If just the outside is wet, then it is most likely leaking from another source. Also check the rear gasket of the intake and be sure it hasn't given up and let oil run down from there.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
