Advancing Cam Timing
I am advancing the cam timing on my 390 to pick up a little more bottom end. I have pulled the water pump, pulleys, timing cover, chain and cam/crank sprockets.
All has gone well as I have reinstalled the crank sprocket with the "A" tooth aligned with the cam timing mark (6 0'clock position).
I getting ready to seal everything back up..........
What bothers me is...........this is an Edelbrock timing set and on the crank sprocket, besides having the "A" and the "R" on the teeth......it also has "2 deg" stamped on the sprocket.
Would this mean that this sprocket will only advance 2 degrees and not 4 degrees as advertised?
It seems wierd that Edelbrock would make a 3 keyway crank sprocket and then only give you a 2 degree movement.
Has anyone seen this on their Edelbrock timing set?
Thanks in advance.
