Old 09-05-2004, 06:51 PM
Mando's Avatar
Mando Mando is offline
Hi Boxhead,
the kit is made up of straight hard pipe with threaded connections in different lenghts for each section. One runs from the M/C to the T bolted to the main right chassis rail. Two hard lines then go from the T to your flexible line on the R/H side, the other to the L/H side. The other runs from your other M/C to the T bolted to the chassis behind the diff. Your flexible lines then connect from the T to the calipers. Hope it makes sense. I will definitely be at the Nationals next month.
Regards.
Mando
