Old 09-06-2004, 06:38 PM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Lightbulb Here's what my machine shop expert told me as we adjusted my valves the first time...
"You'll need to adjust them every 500 to 700 miles or so until it has a few thousand miles on it, as they seat in and settle". Then if the next few times you check them maybe every 1,000 miles and there's no sign of change, then you can extend the check interval quite a bit."
It's about getting them right at first (We did this at 350 miles and we also re-torqued the heads and the intake, all of which had loosened! I'll check them maybe next spring at the 1000 mile mark and then at 1700 or 1800 miles and that will tell a lot.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
