Thread: 460 ford Crate
Old 09-07-2004, 08:30 PM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Default If it has a mechanical roller rocker/cam
Be SURE to check rocker/valve clearance often (every 500 to 700 miles at first, for instance 300/700 mile points) and to remove the rockers and re-torque the heads/intake/water pump/etc.. at 300 to 400 miles. Things settle in there (gaskets, etc.. and you want to do this for sure!
If things settle/stabilize then you can extend the check interval each time.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
