Heim Joint
Been There. Done That.
Don't use grease fittings. That is old world. The new high strength stuff from Aurora will do just fine. Call Brian at Hoerr Racing to help you with the application 866-851-race
BTW .. That is not your only problem...
The rod ends for the toe link need to be replaced too and most importantly..
The bushings for the toe link under the seat need to be either steel or bronze. Not urethane or delron.
