Moneymanager
Talk to "GroupA" in Chandler. They helped me out with an oddball backspacing needed for the front of my Cobra with the C4 suspension.
The guy there is very creative and can likely help you out. I think we redrilled some 5X120mm pattern wheels to 5 X 4.75in and put steel inserts in them to get what I needed for backspace. Like I said he was very creative...
He can also build you a set of 3-piece wheels in any combination of width/backspace/bolt pattern you want. They are pricey though...
When deciding on wheel size, do not forget to carefully measure for correct backspacing. Max width is only OK if the center of the wheel is in the right place with respect to the hub flange.
Good luck. I'll see you at the track soon I hope!
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
