Keithc8 I figured that someone had done this. Blue thunder heads, where are we at with them and price with you stage 2 valve job? Comp cam has the beehive springs, are you using them? Have 3 reports on, good and bad. Cam lift around 600 is no problem over that not doing to well. You didn't reply on the lean motor numbers of 15.0- 1? Are you coating the piston and head chambers? 40 degres of timing thats a whole new thing also. You are playing outside the box
Just looking for a quick answer. Rick Lake
