Old 09-12-2004, 10:26 PM
2KWIK4U's Avatar
2KWIK4U 2KWIK4U is offline
Cobra Make, Engine: Lonestar LS427, Keith Craft 496 Genesis, 649 hp, 668 ft-lb, TKO-600, Dynatek Stack EFI
Default Remote Oil Filter & Block Plate Ports
Getting ready to hook up the oil lines from my block plate to the remote oil filter. Just want to make sure I'm not getting the lines backwards. I think the output from the block plate is the port towards the front where the oil pressure sender is and the rear port is the return. The flow then routes through the center of the oil filter (threaded nipple). Is this correct or do I have it backwards? Also, I'm assuming that there is no right or wrong direction for flow through the oil cooler, looks the same on either end (Mocal). Thanks.
Brad
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
