2KWIK4U.
The
oil cooler can be plumbed either way.
Regarding the remote block that goes on where the original
oil filter housing went, you need to look at where the line fittings come off your new adapter, make sure the return line after it has gone through your remote filter and
oil cooler, this must go into the main oil gallery, so the general idea is return clean oil at the right temperature (oil thermostat required) into the main oil gallery!
Hope you can understand that!
