Just a quick note of caution. I bought a stroker kit from Speedway which has the scat crank, h-beam rods and cast flat top pistons. This was advertised as a 10:1 compression piston and may very well have been in a 351 engine, but on the 393 it worked out to 11.9:1. Massage the numbers before you buy your pistons to be sure you get the compression you want. The more you stroke it the higher the compression for the same piston. Otherwise no issues with the scat crank or other components.
h dog
