Ernie,
Since you're thinkin has been calibrated at this point, do the following:
Call several cam folks and give tell them you're looking for a roller hyd, short duration with wide lober center and big lift in order to work with about 10:1 CR and see what they suggest for the cams and exact compression before you order the pistons. Give them the numbers I gave you for a starting point and I think they can set you up nicely...
I got mine from Crane and have not had any lifter problems, but its not an FE (?).
Keep us posted.
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
