Answer is simpple:
The internal rotating assy (crank) is either balanced to 28 or 50 oz. Unless you use weight plugs in the crank counterweights or other alternative method of balancing - like for a stroker for instance - you MUST use the corresponding flywheel and balancer weight that goes with the crank (28 or 50oz).
Check out the Bay Area Cobra Club Website at http://www.bayareacobraclub.com
