Notes about torque and trannies
Another case for the T-5:
Will and Bruce from Modern Driveline run a business that does NOTHING BUT sell and service T-5's and Tremecs. They have run a Z-spec T-5 in their '92 fox mustang race car for 6 years. The car puts 486hp to the rear wheels!! So far, the Z-spec has held up without incident. One trick is to use a 100% kevlar clutch, which eases the torque transfer to the trans gears.
Also - an important note about Torque. It is a force, so you can only put your peak torque through your transmission gears with a sufficient opposing force. This is accomplished on a dyno with an engine brake or a viscous damper of some kind. In a light bodied Cobra you will never put your engines peak torque through the drivetrain without breaking the tires loose. You simply cannot make enough opposing friction.
Check out the Bay Area Cobra Club Website at http://www.bayareacobraclub.com
