As stated above there were two cranks made for the 302 Ford. Pre 1980 and post 1980. After 1979 Ford went to a lighter crankshaft with less counter weight. This means they had to add weight to the balancer and flywheel to get it to balance and so you had the 50oz balance. This had caused manyproblems over the years. Now Eagle has changed their 4340 forging where they zero balance or internaly balance with no wight on the damper or flywhell which is the best.
Just make sure that you have the right combination together and the correct damper and flywheel. Have it all balanced and their should be no problems. Good luck, Keith C
Keith C
