Old 09-15-2004, 03:00 PM
tfarhood tfarhood is offline
Cobra Make, Engine: Backdraft #101, 342 stroker
First you need to define what "a lot of money" is. Second you need to define if you want 400 hp at the crank on an engine dyno or if you want 400 hp where the rubber meets the road. 400 hp at the crank is quite affordable, 400 - 500 hp at the rear wheels is much harder to do without deep pockets. Another thing is regarding local car shows. If authentic appearence of an original is important for the showability of the car, then money will again be a factor. If you just want the coolest car at a local show, that is a lot easier. If you give us a little more info about what you really want, then you will get better replies in regard to specific brands and details.
tfarhood
