Thread: 408w timing
Old 10-08-2004, 10:29 PM
MidOHasp MidOHasp is offline
Cobra Make, Engine: SPF1670 Stroked Little Windsor - Runs OK.
Send a message via AIM to MidOHasp
Whose carb?
Demon carbs like a lot of initial timing (14 deg) which means recurving the distributor could help. Or if you have your A/F mixtures set right, you can just run a wee-bit more total timing and make it happy.
I run about 14 degrees initial timing, 33-34 total. Switching from CAM-2 to 92 octane made all the difference and eliminated a stumble I had.
Considering retarding the timing back to 30 total, 10 initial, and seeing how it runs.
J.P.
Ohio Cobra Club
Token Gashole
