Joe,
First, check the wire connections on both sides of fuse one and two, the connections at the circuit breaker and on the starter solenoid.
Make sure that the connections at the ammeter are secure.
If everything looks good, you may have a bad ignition switch or circuit breaker.
I'm betting on a bad ignition switch.
