Old 10-13-2004, 01:59 AM
Hotfingrs's Avatar
Hotfingrs Hotfingrs is offline
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Ernie is right about the reasons for doing the above mentioned. Cylinder pressure doesn't tell you compression ratio, it only tells you the condition of the engine. As an example my engine is 10.5-1 compression. Last year I had 285 lbs of cranking pressure, this year I changed the cam and my cranking pressure is now 185 lbs, with the same CR. The cam was the only change made.
Jack
XSSIVE .....
