Originally posted by dscott
Simon, from the picture it looks like the sway bar is mounted upside down. This would also explain why you have no suspension movement. If you look at the bar I bet it's bottoming out on the frame. Should make a world of difference since the front is probably solid now.
Don
This might explain things
I'll check this as soon as possible.
However I remember the original end links were longer than the stock MustangII parts.
