351W Water pump Inlet?
Hi Bill
Both sides are available, it depends (as say Ron) of your radiator output location. However, it can be more convenient to have the water pump input at the left side (driver side) if you want to install a dry sump to avoid any conflict between the inlet water hose and the external dry sump pump (that is usually installed at the right side in the SBF).
All the best for your project.
Bernard
