You need to get the water pump that works with your timing cover. If you have a pointer on the cover it takes the early style pump. The late style uses a bolt on pointer. If you use the wrong type you will have a hard time setting the timing.
You can get the rad set to any side so it is best to match it to what you have.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
