Those are (inside) custom gussets that were added to the lower control arms to keep the end from twisting off under torque or hard braking. They also need at least one on the (outside) as well, and these pictured are only on the inner part of the control arm.
Its a common mod by any of the major manufacturers that use or formerly used Jag rears. ERA, some Contemporary cars, and some Arntz/Butler cars have them. If you have a car without them, it would be smart to have someone add them, its an easy mod, and helps prevent twisting under load. In fact, if you ask around, some might even say it could save your car and your life.
We just did an Arntz car for a friend and we did inner/outer gussets using channel steel that was corner cut and flush to the corner, on both ends of each control arm. Worth doing...
Keep the rubber side down.
