Old 10-18-2004, 09:51 AM
ERA Tom ERA Tom is offline
Cobra Make, Engine: ERA 675 - 427 SO
Default Anybody running a Richmond 5 Speed behind a FE
Hello all. My ERA will be using a 427 with a Richmond 5 speed. I currently have the Hayes 12-240 steel flywheel, the Lakewood 15210 scatter shield, and the 7041710 Richmond 5 speed with a 1 1/8" 26 Ford spine input shaft.
Here's where I'm confused. I haven't found an 11" clutch and pressure plate with the 1 1/8" 26 spine advertised for a Ford, only GM. If I buy the 11' clutch and pressure plate for the GM setup, do I need to buy the GM throw-out bearing and fork? So, if anybody could shed some light on what I need, it would be appreciated. Thanks, Tom.
