Cubic inches: FE 427, 4.250 bore
Compression: 10.6 : 1 (approx) ROSS - Eagle
Intake Manifold : Blue thunder F.E TWM w 4X58mm Throttle bodies
Heads : Edelbrock Alum, with the usual
Cam Specs: 601 lift- 234 dur ,Solid Comp Cams
Transmission: TKO 600RR Centerforce Clutch
Rear End W/ Ratio: JAG IRS w 3:31
And of course...........
Horsepower @ RPM:640@6200 Calc.
Torque @ RPM: 2800-5900 510 at the rear wheels
