ERA TOM Tom the 2 flywheels a have are drilled for both Ford and GM clutches, 11.0" I have a GM input on both my trans. Use the same Lakewood Shield as your. Have the ERA clutch fork that is modified. Everything works fine. Put a limiter on the pedal like it says in the manual from ERA. You should have no problem. Rick Lake
