In 2005 , the first day DMV is open, be in line and have the following ready.
1-Your MSO.
2-Separate invoices documenting , the car was an INCOMPLETE car. Engine transmission etc, came from somewhere other than where the car came.
3-Fill in all the paperwork, you will be given.
4-Be prepared to write a check for the fees and the taxes.
5-The clerk will call Sacramento and get you a Sequence number. You will be given a Temporary Registeration to affix to your car. (Expires in 60 days I believe).
6-You will have 60 days to go to CHP for them to assign a VIN number.No charge.
7-Then you will go to BAR for the emission testing (Can't pass or fail).
8-Depending on the DMV office you go to, they may also require a Brake and Light Inspection.
After you have all of the above completed, you will return back to DMV to finalize your paper work.
You will then get your title and plates.
NOTE: Do NOT leave the DMV office during your first visit without getting a Sequence Number!!
You will receive the Original (Which You MUST have) within 10 days or so before you can go to BAR.
Good Luck.
Any problems, tell them you know ME personally.
TURK
OBAMA IN in 2012
