Old 10-20-2004, 10:37 AM
S_Beaudry's Avatar
S_Beaudry S_Beaudry is offline
Cobra Make, Engine: (building) - Hunter #74 w/ 302 small block (320hp under the hood). . . how many wires are there in a wiring harness?
Send a message via AIM to S_Beaudry
Default Missing Ignition Part . . . . Help!
At a loss for the correct term here . . . .
I guess I need a "relay" or something that is between the battery + and the ignition key switch which is rated at 15 amps that will cut down the 750+ amps from the battery +.
I am trying to do some out of car testing, and not using the fuse box in the car.
Are these "relays" just generic?
Is there one usually built into the fusebox when I wire it that way?
Any help greatly appreciated . . . . .
I'm not busy because I did it right the third time . . .I think!
