Old 10-20-2004, 08:22 PM
hurri10209 hurri10209 is offline
Default know alot about cams?
ok so i'm building my 347 stroker, i'm being told the AFR 185's would be perfect, the 205's will work great, i'm lost, i already bought the 205's, but i'm willing to sell them if they are to big, the set up i'm planning on running is,
347 stroker
keith black piston hyper
scat crank
eagle rods
edelbrock jr. vic intake
holley 750
afr 205's
my question is, will this cam work, i was messing around with desktop dyno and punching in different numbers, i'm not sure how cams work to well, i understand they open the valves and all that, but still don't have a complete understanding, so if you know alot about a cam can you tell me if this will run.
lobe center 114
intake crank deg. 230
exhaust crank deg. 235
valve lift .600
and that is @ .050
i've just been playing around and i made these specs, and it shows good on the prog. 588hp@6500 516tq@5k
above 400 ft-lbs from 2000-7000, so if any one knows alot about cams, if you want to help me out it'd be great(and i know i won't be able to take the engine that high, i'm planning on 6200)
