Old 10-21-2004, 05:14 AM
John Poling John Poling is offline
S_
If you are holding the starter solenoid in your hand as if mounted to the firewall. In other words, the solenoid cylinder is between you and the mounting bracket with the 2 small terminals pointing at you. The cable from the battery should be connected to the large terminal on your left side and the starter cable connected to the one on your right. The wire coming from the ignition switch to the starter solenoid should be connected to the "S" terminal and the only thing that should be connected to the "I" terminal is a wire that goes from the starter solenoid to either your ignition coil (non Duraspark II ignition) or to your ignition control box depending on which ignition system you are using. The "I" terminal is not used on all systems. This is where you need a pin out for the system you are using.
Does this help? If not, please clarify more here.
John
