Old 10-21-2004, 05:39 PM
My427stang My427stang is offline
Cobra Make, Engine: ERA, 496 Tunnel Wedge
Send a message via AIM to My427stang
Michael Henry - The automakers used short initial mostly for emissions, even when the rules were very basic.
In addition, the stock setup had up to 36 degrees of advance in the dist, and it came in slowly to be able to run on almost any kind of tar available. Take a stock 428 CJ and change the curve to what I mentioned above, and watch it jump, but odds are it wont pass smog like the stock setup would, even worse if you add more initial
We are running into this right now with a roller cammed 351C we are trying to pass smog for Nevada. I took the distributor, gave it a pile of centrifugal (28 degrees, but not in untill 4100) set initial to 6, and put the 195 thermostat in. We havent tested it yet but odds are it will pass. No changes to jetting. A solid roller 250@.050 single plane 351C
It'll run like $hit, but it'll pass because of the hi EGT finishing off any hydrocarbons, then we go back to a quick curve and moderate initial and all will be fun again.
1994 ERA Cobra, 496 Genesis FE TW (new addition to the stable)
70 Mustang Fastback, EFI 489 FE TKO-600, too much to list
71 F-100 4x4 EFI 461 FE restomod
Bullock's Power Service, LLC
Concours and performance engines by appointment only
https://www.facebook.com/BullocksPowerService
